Home made light bar. Keep It Stupid Simple style
Northern Illinois
So a couple of years back I bought a Dakar Light Bar by Rampage.
In spite of the fact that the directions were the worst ever, it served it's purpose. It held lights. Sure I had to add vibration isolation pads to minimize the vibration effect while driving, but no harm done. It worked.
Well it rusted through. :( The tab that meets the bar rusted where it was welded.
I had a guy at the shop grind it down and reweld it for me, and just a couple of weeks ago the other side rusted through
So while this product was "fine" for a while, over the test of time it was "poor".
So I got out a tape measure, some paper, and my holy jeans and took some dims. I brought it to the shop and made a very simple light bar. I kept it simple because I like simple. While some are very happy with fancier tube work, this is very utilitarian and can be fabricated easily. Our welder dude was all over me because he could have done this, and that, and the other, and I said no. :D
I used 1-1/2 x 1-1/2 x 3/16" walled tube, and some 1/4" x 1" bar stock.
Here is the 'old and busted'
...and for those who asked and asked how it was mounted since the directions were illegible even when compared to the directions for an IKEA desk, here is a photo.
And then here is the new KISS Light Bar.
It looks simple, right? On the verge of utilitarian? Perfect.
First I removed my bezel and tupperware bumper cover. I removed 'old and busted'.
I then mounted this simple piece of tube to the front portion of the structural bumper (what is removed when an after market bumper is installed)
Oh yeah, I got blasted with high winds, a thunderstorm, a sun shower, and the most refreshing spring downpour I can remember. I felt alive. ...but back on track here
I then lined up the mounting tubes on the KISS bar with the plastic grill, and cut two holes to accomodate the tube penetration. I just used tin snips. ..and then re-installed the front bumper cover
Folks, this just slides in and bolts to the installed structural tube. :)
So while the storm clouds moved off to the east and the sun started to set
I realized anew how wonderful the simple things in life are. A spring shower. A sunset. Strong steel. Simple designs. ...and two hands that can create a simple thing. I certainly am no Lucrum, Demello, or Bandi, but there comes a certain satisfaction of a job well done when you do it all from scratch.
Nice work!
I think I would have added a tow point, or reciever to make it dual purpose.
Looks nice... the rain that is... haven't seen much of that stuff down here in Texas!
I like the idea and that it doesn't try to do to much, adding a tow point to something that mounted over the bumper seems not the best geometry unless you end up stuck in 33"+ of muddy water alot and even then I wouldn't want to pull with them much seeing as they just bolt on to the bumper with two small bolts. /MHO
The tow point I was refering to would be in the center of the bumper not up by the lights. ;)
Dragon,
1LoudLX pointed me here. Great work! Along same lines as I had planned. Might steal some of your (realized) ideas...
If you are concerned (we all are) about the driving lights vibrating, put in a top brace between light and grill. I posted some photos of them here (very common in Northen Sweden, primarily in order to not f-ck up the light alignment): https://forum.ih8mud.com/100-series-cruisers/271860-aftermarket-lights-stock-frt-bumper.html
/// Per-Ola
