home made canoe rack
The Grove
look no rack
little bit of steel
little bit of glue
gets you a new rack
80 needs paint
i still say hydraulics are your friend
hand hammered goodness
Sooo, just how much does the rack weight???:hhmm:
I'd consider adding another leg- right at the C pillar.
Not because the canoe needs it, but because sooner or later... you'll add something heavy.
2x. The rest of the design is seriously overbuilt for a canoe. Two load bars would have done the trick if that was the limit of your intent.
The interface from the rack to the 80 though... needs more thought.
Since you clearly have the skills to do it - maybe go to 4 supports on each side. Push the front and rear supports as close to the A and D pillars as you can. Then put rack supports right at the B and C pillars. At that point you should be able to walk/sleep/party up on top of the truck.
Very cool fab skills on the drip rail mounts.
I agree on four supports, but enlighten me on the interface. I'm not quite sure what you're talking about.
Interface = fancy generic name for connecting one thing to another.
In this case the supports are the interface between the rack and the roof. I think your supports themselves are excellent - just need more of them if you plan to use anywhere near the capacity that robust rack like that can hold.
If you get into that kind of weight though... you might find yourself cracking the pillars at some point. I'm not sure where that point is, but I remember a while back seeing pictures of cracked B pillars.
from the pic, I can't tell how you tighten the mounts to the drip rail, but I would want something that you can torque down snug and also adjust easily.
I don't know if it matters one way or another, but I plan to slightly round the corners of the steel that sits inside the drip rail- on my old cruiser you could see where the sharp 90* corner had chipped/dinged the paint... two distinct rust spots on each foot. Slightly rounded might not matter, but it'll take 20 seconds / foot with the grinder.
I also added some plastic hose (cut lengthwise down the middle) to the rack feet. Also to prevent metal/paint contact.
Ok I got ya now Grench, I'll probably end up with 6 or 8 total. I've had my 200lb butt up there dancing a jig and couldn't budge it. It's hard to see but there are rubber hose pieces under the feet. Creepersleeper I'll get more pics when I get home. I'm not sure how to get them off my phone.
Thanks for all the feedback.
Jeremy
if you can come up with a way to mechanically clamp the foot to the leg, that'll work better.
ie: a vertical threaded shaft that you can torque down, connecting the two different parts of the mount.
