HJ75 Wilson, glow plug issues-- ideas?
OK, here goes:
Have a 1985 HJ75 with a Garrett Turbo added after. 12v system, but maybe 24 volt starter---not sure. It also seems to have a Wilson switch (button to right of steering column - it is RHD) and a secondary starter button under steering column. The truck is very well maintained and in very good condition. All aftermarket parts the former (Australian Geo survey guy) put on are top rate.
He is the issue. We are blowing glow plugs like toilet paper. It seems we can glow with the key, i.e turn key on to get lights and gauges working and you can here the glow plug click to warm. We can also use the bottom to the side of the steering wheel for the Wilson switch. And we can crank her over with either the key or the button under the steering wheel.
When we replace the glow plugs, she starts right away no matter the cold, etc and runs like new. But a few starts later she will not start again. So pulling the glow plugs and checking with ohms meter-- they are shot.
Therefore we put a volt meter on the glow plugs and bar and here is what we get:
1) Using the key there is 12v for about 75 seconds, then it drops to 5 volts for a long time (must be connected to a thermistor but we were testing without the engine running so....)
2) Using the Wilson button we get 12 volts for as long as you hold the button.
So it seems, maybe the owner had a bad glow plug relay and put in a Wilson switch. But how the hell did he get his key to the "on" position to run spedo, lights, gauges, etc without causing the glow plugs to fry? Does the system not glow via the key if the engine is warm and up to temp? I.e not superglow at all? Did he start with the button and wilson to bypass the ignition and then turn the key only when the engine temp was up (which you cannot see since the temp gauge will not work unless the key is on - you could guess clearly). He lived in Australia where cold in not an issue (we are in New England., not too bad, but cold enough).
Is this a normal way of doing things in Australia I do not know about? Am I screwed up in what all these things need to do an in what order. It seems the best thing would be to disconnect the old OME glow plugs from the key so we can just use the key alone. We would like to use the key since the drivers of this vehicle changes everyday to people who have never driven a LC75 or a diesel at all.But does this mean we start with 12v or 24.
If I do disconnect the OME system, how is it best done? I need to get new glow plugs---what should I use. We have been using what came out of it VSP pt-104 8.5 volts.
Can the Wilson switch be connected to the key so it can be glowed with a 1/2 turn on the key like the BJ75?
Open to suggestions. If i am not clear with all this, good chance, please let me know what i need to tell you.
thanks
I have a button that is pushed when the ignition lights come on. Simple and only needs to be glowed once a day for 10-15 seconds or less on warm mornings.
Australian spec landcruisers are 100% 12 volt,there shouldnt be any 24v parts on board
The glow plugs glowing for 75 seconds or more is too long and is burning them out.
Normally in australia if the glow system packs it in ,they have a system like mine.
They have tried aftermarket timers but they dont last.
so do you all just disconnect the key glow plufg system...if so what are the steps to doing this correctly?
What glow plugs do you use then? 6v or 8.5v or....?
thanks very much for the help
Bruce
Hey Bruce,
I would get one of these:
Glow Plug Numbers
Manual 12V
10.5V for a 12V Cruiser
1980/10 – 1981/10 Cdn Spec BJ60
Toyota=19850-68010 12V-10.5V
Nippon Denso=067100-1330
NGK 7493 (Y-147T old number)
Bosch 0250 202 058
(Copied from Greg Bowies post in the Diesel section Parts # thread) That way if you are giving it 12V and hit the button a bit longer, I would think these would last you a bit longer.
Cheers,
Deny
Great, thanks.
Ideas on best way to disconnect the original system? This truck has an Edic, so....? Do I just do it at the ignition or after the OME glow plug relay?
Great, thanks.
Im not too sure on that. My system was installed after an engine swap .As it prieviously had a petrol engine ,there was nothing there to start with.
My glow plugs a 9v(I think) for a 1HZ
Hey Bruce,
Glow Plug Numbers
Manual 12V
Bosch 0250 202 058
Cheers,
Deny
Opps I goofed, gave you the copy of 3B glow plugs, below are the numbers Bruce posted for the 1HZ in the Diesel section parts # thread. Sorry.
1HZ 1HDT Glowplugs
A few more numbers that may help...
It looks like it's the same glow plug PN for 1PZ, 1HZ and 1HDT (12V system, 11V plug)
Toyota/ Denso 19850-64031
NGK Y-715R
EIKO - GT220
Bosch - GPT220
Champion CH153
HKT - PT-152
NGK - Y-T02
Dreik DGP2042
Diesel Truck Part - DTP 02 597
