hj75 chassis numbers
Its usually on the tag like this one. Thats for a 61 series and tells you its a RH aussie turbo model with a tail gate ,but the 75 series tell you whether it was a cab chassis meaning cab only or a complete unit with a tub affixed. You need the decoder but the TLC FAQ seems to have been removed from its server.
But if you can get the bit where it says HJ75R***** someone may have the decoder
Those chassis' were also used on the troopy and I wouldnt be surprised if they just go them out of stock and used them on what ever it was needed for.
We're HJ750001391 as a RHD troopy. I'm assuming means it is the 1391st 75 series frame with a 2H engine to roll off the line regardless of bed/cab/box option? The model number defines the style option, like HJ75RV-xxxx.
