Hj61 sahara overhaul
Motor is alot quieter but still using a little oil,just replaced turbo so that should help.
It will do for a few years but i think it may of prefered a bore etc. When its cold its still blowing a little blue smoke.
Maybe the rings will bed in further im not sure?
I have a BJ60 that I'm swapping an HJ61 body onto. Cutting out my dash to keep my VIN and LHD, but I'm excited to have a High Roof soon!
Question to the OP: Looks like you removed the sunroof. I would like to do the same. What did you use for a filler piece? Did you just weld and bondo? Where did you find the inner roof supports where the sunroof frame used to sit?
Thanks!
Hi peezeed,dont check in that often,replied to a pm the other day about something,not sure if it was you,the roof supports i got a couple out of wrecks,i cant remember if they were 60 or 75's sorry,just modded with some plate on the bottom,just had a look,two rears look standard,you have 3,looks like ive got a rear out of high roof in the middle,front one might be 75 or 60?
You can bend them a little etc to fit,take a pic and put it up....
