HJ60 2H Radiator question
Mooresville, NC
Good morning,
I had my original 2H radiator repaired about 4 years ago or so and it’s now leaking at a couple of seams towards the top. It was repaired by an older gentleman locally well known and recommended. With the assumption that it’s at end of life, I’ve been researching a new radiator.
I’ve really only been able to find either an aluminum (plenty of options on EBay) or an ‘original’ looking radiator Here.
I really want to try and keep original appearance but +$400 seems high.
So two questions, 1) are there any more affordable options for an ‘oem’ style?
2) Have any of you replaced your original with an aluminum? If so, are you happy with it and did it install with no mods? I’m worried about buying one and then having to do more work to make it fit.
Thanks for your help!
Some run champion aluminum radiators on 12HTs. Pinging @CenTXFJ60
I’m about to send it and purchase the one above while I wait to find a shop that will recore my old one. Every shop I’ve called here in El Paso said they can’t do it.
I’ll let you know how fitment goes!
I am planning on getting the aluminum also... I am in NH and will let you k now how I fare. The link you posted is for an FJ.
Just installed that one in my HJ60.
Fits like a glove.
Just needs a bigger size radiator cap.
Fits like a glove.
You mean the one posted by @seapotato ?
Also, did you order a rad cap? Other ones I were looking at voided warranty without proof of purchasing a new Rad Cap anyway, so I was planning to order that too.
I was able to get my current radiator (that was leaking where the inlet tank meets the core) soldered for the time being.
FYI in case someone is looking for a 2H radiator - just installed a radiator found on Amazon. There are a ton with slightly different pics/descriptions on EBay but after finding this one off Amazon with free returns, decided to roll with it.
A little risky (no reviews/Chinese) but wanted to get my cruiser running.
I was shocked at how well it fit. Literally every bolt lined up perfectly except for the bottom two shroud bolts. Easy fix by adding holes to the shroud.
