I have an Australian spec HJ45 built 11/1978 fitted with factory drum brakes front and rear, given the below information what spline count should I expect to find on the axles?
Birfield Joint Renditions:
68 - 9/75 - Course Spline, drum brake, small shell.
9/75 - 1/79 - Fine Spline, disc brake, small shell, longer than later 79-90 birfs.
1/79 - 1/90 - Fine Spline, disc brake, larger shell, shorter than 76-79 birfs.
1/90-97 - Fine Spline, disc brake, largest shell, available with ABS toner ring.
