Hj45 Alternator wiring
Costa Rica
Hello all,
I recently bought an HJ45 with an H engine and Ive been going through the wiring since its a mess.
Turns out the previous owner removed the alternator connector and directly wired the harness to it.
Alternator has 3 wires:
2017807
But the harness only had 2 wires :/
While removing the electrical tape the little white wire came loose so im not sure if it was connected to the red one or the geenYellow one or to none at all.
The alternator is a Denso 27030-47033:
2017809
Does anyone have an idea how each wire should be connected ? I know the greenYellow one is the generated 14V+ . but im not sure about the other 2 white and red wires.
Thanks!
The red wire is probably the alternator field wire and goes to the external regulator F terminal. The white wire is probably the Charge Lamp wire. You do not need the white wire connected unless you have a Charge Lamp.
Alternator red wire was connected to a harness white wire... which does in fact go to a "black box" on the external firewall. I'm guessing this is the regulator you mention:
2017992
From there, a second red wire goes out of the box and into the cabin... still need to check where to exactly. Is this box grounded via the screws that attach it to the firewall? I cannot seem to find this 3-pin regulator box on this wiring diagram:
Thanks for the info!
The schematic shows the regulator as being a 5 terminal, you have a three terminal which is fine. The regulator does ground through the mounting bolts.
The three terminal regulator has an F terminal (the red wire that goes to the alternator field) and an IG terminal (the white wire which should go to a key switched +12V) thats all you need.
