I'm with JD on the sticker. In no way does it indicate a safe load rating for bumper towing as seems to be under discussion. Check the bumper on a Ford F150 and you'll see an actual bumper tow rating stamped on it, which is what Toyota would have done too if they rated their bumper for towing. They don't. Assuming the 3500 on the sticker means you can tow it on the bumper is quite a leap and incorrect.
I don't know of a way to say this without stepping on toes, but I don't think the bumper holes would be rated at much over a garden trailer if subject to a factory rating test. 1500lbs - ish. Yes, it seems some are successfully towing much more than this but that does not make it right. Those tows are being done well outside the engineering envelope of strength, and its worth considering if you could live with being involved in an accident and the trailer got loose and killed someone. Or the rear member failed in a crash and the trailer tongue speared your own rear seat passenger.
The ratings of hitches and towing gear are not set with the priority on whether you can tow with it. It's the worst case crash scenario, the stresses of lots of towing miles, the fatigue of fasteners after 10 years in the rustbelt, etc. Even with these standards in mind tow equipment does occasionally fail. So I urge folks who are towing to forego saving $100 or preserving some departure angle and use the heavy tow gear. Your life, or the life of someone's loved one may one day suddenly and completely unexpectedly depend upon your choice.
DougM
DougM
