hill/steer wobble
In reviewing the notes I got from the PO here is what I found with my issue:
"It's the front knuckle bearing preload shims. ?
The only way for the preload to be bad is if the bearings are worn out. Do not fool with the preload without checking the bearings for wear first or you may not be able to turn.
Death wobble can be caused by so many things that it will be expensive to solve the problem just by replacing parts.
There are two general classes of problems:
1) Slop in anything that locates the wheel.
Put the axle up on jack stands and start shoving the wheels back and forth, in and out and check for anything that moves that shouldn't move.
2) Wheel alignment. Too much or too little toe in which causes side to side forces on the wheels. Too little caster which makes the wheels self center.
Figured I post an update. Got new tires and rims and that seems to have made things much better. I did purposely nail one pothole and it shook very briefly then connected itself. Once other when i braked hard and turned but again it corrected itself quickly. However the shake after 40 was gone
Im thinking needs new shocks?
