Highest air mode button not working
Fayetteville, AR
The highest air mode button is not working on my 97 LC. So the highest it will go is technically the next to highest setting. Is there a switch that needs to be replaced?
Thanks,
Travis
Thanks,
Travis
I'm assuming you are referring to the blower motor fan speed for your A/C - Heater?
IF you have all speeds except 'High', you'll want to check the connection on your high speed relay (behind the glove compartment).
It is also possible the dash mounted switch is at fault, or the relay itself.
Thank you!!!!!
