High temps! (what would you do next?)
Tucson, Az.
Well, I am at a crossroads with my cooling system. My rig is a 97 that I have had for 2.5 years. It is lifted, armored, etc, etc. I replaced all hoses when i bought the rig and did a cooling flush. Since then I have replaced the fan cluth and added 10K weight oil to the clutch itself. Scangauge still gives me readings of anywhere from 193-200 even this time of year! (Tucson, Az)
My question is "What next??" I am thinking of replacing the thermostat and maybe a new radiator this year because in the summer I tow a couple of trailers and doing this I would see temps of 225 or so. Any input is greatly appreciated.
I would do the t-stat first since it's cheaper. If that doesn't fix it then it's probably time for a new OEM radiator.
Search should yield a great deal of information on the subject, lots of threads on this subject recently.
How well did you flush the system? Can you see slug deposits when you take off the radiator cap? How is your belt tension?
Good luck and keep us posted.
