High powered alternators
South Mississippi
I am going to spend next weekend on a dual battery setup and wiring my winch and unsure if my stock alternator is up to snuff so looking into higher output alternators for the 92 EF-E.
Unfortunately we can't go the Sequoia route and after searching I have learned that Mean Green is pretty much a ripoff.
Anyone have any advice on a replacement alternator that can handle 2 red top Optimas as well as my winch? I am going to use just a simple Kenwood radio with the built in amp, have HID lights, going to put on some driving lights, and an always on fridge in the back.
I found this one on eBay, 180 AMP Alternator (88 89 90 91 92) Landcruiser : eBay Motors (item 220478517098 end time Apr-07-10 10:45:36 PDT)
So all you did was essentially grind off the back tab and it fit?
pretty much, there are pictures in the thread I linked of what I had to grind off. I also enlarged the wiring connector, but I assume you would be replacing that with the dual battery setup anyway. I have heard several people mention a bracket that you can buy to fit the 90 amp, but I have not actually heard of anyone installing it. grinding the notch in the back tab was probably easier than installing a new bracket.
Yea I will be replacing all of the wiring coming off the alternator anyway.
I didn't think 90 would be enough but as long as it charges the batteries, the rest of my setup is pretty minimal on the electricity until I get into winching which the batteries should be enough for.
Its another case of which dual battery setup he is going to run. If its a hellroaring kit like I have in my Tundra then there is no factory wiring to mess with. Some require cutting in and splicing alternator circuits.
