SSBOB wrote:
"Originally Posted by ssbob
Since we are on the subject of wheel noises I have one I could use some thoughts on. High-pitched metal on metal kind of sound that only kicks in when moving and only after a while of driving (30 minutes or so). Brake pads are at 1/2 and rotors are new with no grooves or chunks missing. There is little or no play at 6 and 12 o'clock and the same at 3 and 9. When applying the brakes the noise does not immediatly go away, only when I slow down to under say 20 mph.
Any thoughts?"
SSBOB,
You described to a T what I am hearing on my 93. Been listening and figuring for a week. I think it's one of the wear indicators dragging on the disc even though I *thought* I just bent them back out of the way at my tire rotation last month. Same deal - it goes quiet around 20 just when the wind noise drops to where I might be able to figure it out. Also, I shut my car off and the noise stayed the same - so not engine/belt/tranny pump, etc.
Can you get someone to drive it along a building with you in the rear seat so you can figure out which side and then which wheel? Mine's the right side, and I'm going to have my wifey drive so I can figure out front or back.
DougM
Any thoughts?"
SSBOB,
DougM
