High Idle....Maybe?
Orange County California
Hey all, i just had my rig worked on and now my idle runs high (around 1100 RPMS) when in park. Below is what the mechanic did. After the work the rig runs a lot smoother and my drive/Rev idle is now where it should be at 650 RPM's. And it also shifts a lot smoother. I have checked all the hoses under the hood just to make sure nothing was loose after the work was done. I have also checked my throttle cable by trying to lift up my gas peddle. Any idea's? Below is what was done at the shop.
* Adjusted kick down cable
* Adjusted throttle cable
* Adjusted timing (advanced a little)
* Valve adjustment
* Cleaned throttle body
* Changed all belts
My guess would be throttle cable as well but id be curious if he really adjusted valve train. Not a quick an easy feeler guage task like some other motors
Well, the mechanic is a reputable Toyota/Land Cruiser mechanic so im assuming they knew about the terminal jumper. but if my idle is ok while in drive i don't think the throttle cable would be the issue right?
I also check all hoses but could not see anything noticeable.
