High EGT
Lompoc, CA
This started in the thread about feedback on Landtank's MAF:
https://forum.ih8mud.com/80-series-tech/223216-landtank-mafs-my-experience-what-yours.html
To recap - the issue is that I have always (5 years experience now) seen higher EGTs than most rigs with the TRD S/C, and that has remained consistent following my recent HG replacement, complete with valve job, injector cleaning, new fuel filter, pressure regulator, all fuel hoses, and Rick's new MAF. My O2 sensors and fuel pump are about 3 years old, but are very low mileage - probably less than 20K. The old pump sock was spotless when I pulled it.
In level cruise, I see ~1000 deg at 30 mph, 1200 at 45 and 1300 at 55-60. A long uphill pull with 5-7 psi boost will show 1640 (if I let it). These temps are consistent before and after the recent refit, and with both my original Autometer 1600 deg analog gauge and current 2000 deg digital. I live on the chilly CA central coast and have not had the truck out into hot weather in quite a while, but the cooling system is also totally updated with every mod that's been developed here except an electric aux fan. I have a fairly large aux engine oil cooler fitted as well.
Rick -
I have an AutoXray 5000 scanner and can read O2 sensor voltage as I drive, but I don't know exactly what to look for - also don't know what's involved in getting wideband data. Your thoughts and guidance are greatly appreciated.
Later, Mack
Well Mack I think your high EGTs are coming from two possible places. You could be running lean or you might have an exhaust restriction.
Running lean is by far the more dangerous situation and the first thing I'd try and rule out. This is really an odd thing to happen on the OBDII trucks as they have historically running incredibly rich.
My first idea would be with a O2 sensor problem. This is the single piece that has control over your AFR. I had a sensor that caused the truck to run lean and it never threw a code as the one device to see a lean condition was actually causing it. The best way to confirm a lean condition is to get a calibrated wide band sensor on the truck and take some readings. They have mounts that attach to the tail pipe instead of the exhaust pipe just after the manifolds but you need to be certain there is no leaks in the exhaust otherwise the readings are worthless.
On the exhaust side a restricted CAT can cause heat to back up. I've seen our CATs get partially clogged so you might go ahead and take them out for inspection.
Rick -
Thanks for the steer - I'll see what I can find. Since the temps didn't change appreciably - at least that's how I remember and I'll try to find some old notes - when I swapped out both O2 sensors a while back, I think your clogged Cat hypothesis is the more likely winner. It also squares nicely with my current run of crappy automotive luck. It will be a little while before I can go after the cats, but I'll let you know what I find. I assume any significant blockage will be obvious, right?
I'll also check around for a wideband sensor, but I will have to get help with that approach.
Thanks, Mack
Dusty -
I'll never really be comfortable north of 1600 deg, but glad to know I'n not alone up there. I guess I can see a whole new exhaust in my future. When I first saw how the pipe was flattened out back aft I first thought it had been crushed, then I figured out that it was intentional - still can't believe it. There's a local guy with a muffler shop who used to be a nuke sub qualified welder - I'll have to go see what he thinks I should do. Thanks, Mack
