high EGR flow fault code question
what vehicle? your 4 runner?
on a 1FZ it makes it run a little rough when cold, if its a 96 and newer if it has a code it will not pass emissions in most states, other than that really no effect
To quote the following document:
http://www.autoshop101.com/forms/h61.pdf
Too much EGR flow and/or excessive flow for driving conditions may cause stumble, flat spot, hesitation, and surging. Because EGR dilutes the air/fuel charge, too much EGR for a given engine demand may cause a misfire. It is not uncommon too see tip in hesitation, stumble and surging when too much EGR is metered.
I had that code for a few months. During that time, I passed emisisons fine (after clearing the code and before it reappeared) and experienced none of the above symptoms. In my case the VSV quit operating properly, so my EGR was active all the time. My EGR modulator was fine though, so the correct amount was metered. The EGR just didn't shut off for cold starts, idle, and heavy acceleration.
Depending on why you have excessive flow, you may or may not have the above mentioned symptoms.
