I was wondering if anybody has done a high compression build yet. I know a few have done rebuilds that they increased compression by .1 or .2, but I am speaking of builds that 10:1 or more was achieved.
On paper mine is pushing around 9.5:1. This was achieved by decking the block and milling the head down. Keeping mind, you can only deck and mill so far on an OHV engine before you start to experience timing issues.
Achieving much more than that will require either higher compression pistons, custom HG, or modifying the cylinder head. Even so, going from a stock 9:1 to 10:1 will result in less than a 3% power increase.
I build high comp turbo motors, way better than low comp turbo's.
Yeah, but you sure can't boost much (not that it matters on a truck I guess) with 91-3 octane, no matter the tune. You'd have to run at least some Cool Blue to boost any decent amount (~1 bar), and that gets stupid expensive at every fill up.
With a street driven sports car like a Z (Z32) or a Supra (3rd or 4th gen) or something, I rather have the stock compression (8.5:1), or just a bit lower, at 8:1 maybe. Then you can use a C16 mix and run over 20 pounds (with no cats of course).
EDIT: I remembered reading this post on SF with a retardedly sick 1FZ with monster boost
AWD Supra with 1FZ and 98mm turbo is almost ready... - Supraforums.com
