High beam switch going bad?
Leesport, PA
Is there a switch is the steering column for the high beams that goes bad? My high beams work intermittenly when I press the wand towards the dash, but work fine if I hold the wand towards me. I searched but found nothing.
You're not likely going to get anything here on that. My 93 had the same problem only it never worked when I pushed it forward. Eventually it stopped working when I pulled back as well. Bulbs and all were fine. From what I could tell I was missing one of the balls or one of the contacts was bad in there. I never did fix it.
Give Oleg a jingle at Irbis Off-Road. He can prolly get a new switch for you for cheap.
From memory, yes. A rectangular thing with a post (the switch) poking out.
Was a pricy part they didnt stock, too.
I think it is an 80srs Im thinking of.:confused:
Time to pull the top and bottom off your column to see.
Matt
mine does that but in reverse, when I have the headlights off and i pull it towards me to flash my high beams, my low beams end up being used for the flash. same when i have the lights on, except nothing flashes b.c the lows are being used. it does work though when i push it towards the dash high beams turn on. wouldnt mind fixing it but it hasnt bother me to the point where i have to research it
Did you ever figure this one out? Mine is exhibiting the same behavior. Pretty irksome.
You might get lucky and be able to cure it by spraying some contact cleaner in/on the switch while putting it through it's motions. This worked for me on my 82 Hilux. I didn't even remove one single part: Just grabbed the stalk and moved it in each direction while spraying at the base of it (where the actual switch mechanisms are). It instantly resolved the problem, and it's been good for over two years now.
If you try this, report back, ok? I'd like to know whether it's a real fix or mine was just a fluke.
Curtis
I tried the contact cleaner trick--sprayed just a little into the base of the stalk while working the highbeam switch both ways. Seems to have done the trick. I'll just have to wait to see if it keeps working.
Thanks for the tip!
I had the same problem on my '97. Ended up having Toyota replace the switch while it was in for other service. Wasn't too pricey, as I recall, or I wouldn't have had it done...
