High-Angle CV Boot Recommendations
Not sure I understand "Dana 60 architecture" as a Dana 60 is a solid rear axle without CVs or even U-joints/birfields:
The axles feature a double-offset inboard CV joint that is comprised by 1-inch balls and 300M internal components. The outboard CVs utilize our Dana 60 architecture with combination of 4340 & 300M components optimized for maximum strength. The center bar is 35 spline 300M, the strongest in the industry. The RCV developed moly SPEC grease is used in the CVs to control heat build-up in even the most extreme use environments. Black oxide coating is standard.
But it does seems like these are using high-strength steel and bigger parts in the actual CV joint. Probably a good mod for a trail-specific rig, but overkill for everyone else :)
It's really interesting, and yes overkill , but what exactly do they mean with that statement.. Now I'm curious ..
I just remembered that Dana 60 front axles do exist....but usually use a traditional U joint and not a CV. Definitely curious. the RCLT setup uses extended versions of these as well (with the $2.2K price tag on top of the $7K RCLT price tag!)
Any additional update? I was looking at the same kit for my fjc, after busting 3 cvs in a year I'm trying to find a longer term solution without breaking the bank. Do you think I'd be better off buying the boots and tool separately?
My first set lasted 3 years, which was great. I re-booted them last year and one of the boots is already cracked pretty and the other has a pinhole. It's a legit All-Pro kit I bought from Summit Racing, but was a spare kit I bought a couple of years ago and had sitting around. I'm not sure if the rubber degraded from sitting in a box in my shop (seems unlikely?) or if the quality did go down. Either way, I'm going to reboot them with another All-Pro kit in a few weeks and see how they do. If they tear in <2 years again I'm going to upgrade to 5th gen 4Runner axles which I understand have better OEM boots.
The CV clamp tool they have sucks. I'd buy the kit without the tool and get you own - I have a Lisle tool which is pretty nice. I think a pair of pex clamp pliers would also work fine.
