- Joined
- Sep 26, 2003
- Threads
- 117
- Messages
- 11,199
- Location
- Lancaster, Ohio, USA
- Website
- www.tlcperformance.com
I seem to recall reading that direct from the factory, you could buy a high altitude 40 with high altitude jets.
Yes, 75-78 2F could be optioned with hi-altitude carb & emissions.
Earlier models came with the hi-altitude jets stored in the carb, 79-newer were equipped with Hi Altitude Compensation system to change mixture automatically.
Free advice: The fact that it starts cold with no choke indicates it's very rich. A carb or injection that is tuned right at normal operating temp, needs cold enrichment. Related, there should be a hesitation without choke when cold. Finally, consider that starting & idling & tip-in throttle are mostly the slow circuit. Rather than drowning the main circuit to hide a lean idle jet, just change up the idle jet. That won't kill cruising fuel economy.At 3700 ft, I just started to try the Mikuni (OEM) jets this past weekend. For sure, the threads are a slightly different pitch but I just worked the threads using the front plug that holds the spare primary. I have a '74 carb on my '78 2F.
My primary was a 120 for many years and had a slight hesitation when engine was "cold" (ambient in the 60s in the morning/80 at lunch) until it got to about 130 deg., then it ran great and had some stink to the exhaust. I finally tried a Toyota 136 I had a couple of weeks ago, hesitation when cold was gone, didn't have to use the choke, stink was gone and ran great with more power but, wow, used an extra 1/4 tank of fuel during 4 days compared to before.
