I ordered the phillips 35w HID bulb replacement from xenon depot and spoke to Steve about what was needed to install. It comes with wiring that just plugs into the factory harness inside the light housing and all you need to do is cut a simple hole with a dremel in the headlight cover for the wires to come out to the ballast and return to light the bulb. Start to finish for a newbie was 1.5 hours total after cleaning up.
The headlights have the dynamic projectors which were great with the yellow light that came out before, but it is a totally different world now. The new bulbs put out bright white light and so much more that it feels like a brand new car compared to before. The dynamic function works just as before, it just has a lot more light to play with.
HERES THE ISSUE- there is so much light that I now see movement on the ground from the bulb moving around in the dynamic fixture when I drive thru rough streets. Maybe it was happening before and I couldn't tell because the light was so bad... or maybe the wires are putting tension on the dynamic fixture and helping create a force that can move the bulbs when I hit the bumps. It looks to the driver like a headlight is loose and moving around a little but the bulbs are in right and its the dynamic assembly that is moving.
I'm wondering if the length/position of the wires going back into the headlight cover is putting the back of the bulb in a bind ever so slightly and it shows itself over bumps.
Does anyone else have any experience here?
