Hey folks,
Any recommendations on a hi lift jack?
thx
thx
One More Important Thing: Whatever you decide, make sure you make arrangements to bolt that sucker down. It's the last thing you want to have flying around in an accident!
There is a Canadian made jack, the Jackall, which is the older brother of the American made Hi-Lift. They are excellent quality and the only NATO approved Jack of that type. Not sure if you can find one in TN, but if you do, use it with confidence, unlike the no-name offshore copies....
I use a HI-LIFT 60" cast/steel . I know in the states and Canada there is what is called a Farm-Jack about half the price but the mechanism that holds the handle in place is weaker it is welded.
A can of spray lubricant of some sort is also a must with these tools. I have a can of WD40 in the pocket of my 40 and whenever the jack is used, step one is to spray the mechanism down with lubricant.
Another thing that is easily overlooked using Hi-lifts on the 80 series. The suspension of the 80 flexes so well that there's times that you run out of jack and the wheel isn't even off the ground yet. This can be remedied by using a strap of some sort around axle and frame before raising vehicle, to limit suspension flex. Just be careful of brakelines and other more fragile components when doing this. A good stout rope or nylon strap or even a short section of chain will work. Be prepared to get filthy and wet, depending on conditions. I like the chain method myself. With the right bolt, nut & washer setup, adjustment is pretty straight forward and stronger and easier than tieing knots in straps. Just don't forget to remove it when unstuck.
Tractor Supply Co. is the place to buy if you have one nearby.
I like that idea!.........I always strap the axle to the frame even if I have a plenty long jack, it minimizes the amount you need to lift the truck. I use a light weight ratchet strap. ........
If you have the axle strapped to the frame how will flex affect jacking?...
also- on an 80, I feel like a 60" is pretty necessary. The rear end of a stock 80 can flex enough to make a 48" just about maxed out. Better to have some extra length.
I guess the versatility of the extra length out weighs the storage problems.if you strap the axle to the frame, flex won't affect jacking. Assuming you start with a more-or-less compressed spring. Or at least with a level spring. But if you start with an already drooped axle, the shorter jack might not be enough to move stuff around effectively.
I had an experience just this week where my coil was just about maxed out, with the tire hanging middair and the axle on dirt. I had to raise it somehow, to get ground under the tire (and to get dirt out from under the axle).
Said better-- I could pile stuff without problems, but I had to have a way to put the wheel *down* onto the pile with vehicle weight, to get traction. With the 60" hilift, it touched the bumper with about 6" of hilift left. I lifted about 3"- leaving only 3" or so of hilift. It would have required stacking an unsteady pile of debris/dirt/rock on an unsteady hill, then lifting off of that if I had only had a 48" jack. I would not have liked that scenario.
so.... the flexy nature of the 80 suspension (especially with a lift) meant that I really did need a longer jack in that particular situation.
Another huge advantage to the 60" jack is if you need to use it as a hand winch, the extra 12" is very welcome and means less re-rigging.
in short:
Nothing at all < 48" jack < 60" jack
