First off let me thank everybody for their helpful replies, kudos to this forum
I am now much more optomistic that its actually ok. Here's what happened this evening.
Checking back over the ignition and distributor timing, I finally remembered that while taking the air cleaner assembly apart, I mistakenly disconnected the mass air flow connector wrong. Rather than try patiently to remove the stubborn connector correctly, I went ahead and unscrewed the connector body from the housing, and pulled the connector out. Well, its not designed to come apart this way and I ripped out some of the soldered leads. At the time I thought they were spring loaded and just shoved it back in.
So this evening I cut the silicone seal off the top and repaired the solder joints on the pc board inside. This immediately took care of the miss and stumble. Helps to actually have a working MAF
I continued to let it idle and observed. The bubbling in the coolant overflow had disappeared. It never got hot. It was producing less tailpipe steam but since it was about 38 degrees outside I guess it will still make some steam. The water dripping from the tailpipe is clear. Before the HG replacement it actually dripped green coolant out the tailpipe (scarry). It really runs so smooth and quiet, rock steady idle at 650 rpm, and revs up very easily. Prior to the HG replacement, it was very obvious that only 5 cylinders were doing anything. If the HG is still leaking, it sure does run good. The only indicator left that anything could be wrong is the oil cap is collecting water droplets just like before. I'm crossing my fingers that its just left over water in the crankcase.
If I had somebody to help me put the hood on, I'd take it for a spin, but it will have to wait until I can get my neighbors help tomorrow.
Thanks again for everybody's help, you guys rock!
-Paul in Windsor, Colorado
P.S. I still think you guys get to obsessive about stuff like painting your wheels, powercoating engine parts, and otherwise fufu projects
