I bought a 97 LC a while back and the thermostat was stuck open not allowing the engine to come up to temp. After I changed the thermostat I found moisture under the oil cap. My mechanic friend told me it was just condensation that had built up from the thermostat problem. I haven't found anymore since. Until I did a flush and fill of the coolant this morning. It was very cold, about 28 to 32 degrees, when I did the flush and fill. After cleaning everything up i just happened to check the oil cap and, again, found a slight amount of moisture. Was this caused by the cold water running through the motor for fifteen minutes or do I have a blown HG???? The engine runs like new. There are no leaks, and no oil in the coolant. Any ideas? I'm kinda worried now. Help......
Thanks, SC
Thanks, SC
