HG Failure Pics
Brentbba
Former Golfer
OC, CA
Got the truck back this afternoon. Shop saved the HG for me. Failure on cylinder #1 is very obvious. #6 looked like it was getting close and the other 4 looked good.
Did you ever check the old paperwork to see if you used the updated gasket last time? Failure on #1 is pretty uncommon. Maybe improperly torqued?
If it was done it the past, it is the old style HG that is in the pic, if it was not done in the past. It is orginal
Interesting. I've asked him about that and I think he said the gasket had been replaced once already on his watch (correct, Brent?). I was puzzled cuz I don't think I've read about the new design failing. So that would still leave that new design blemishless then.
Yeah Brett-That's an old style HG-the same type that failed the first time. Time to have a conversation with your original shop (unless that's all that was available at the time).
Hijack for Powderpig--
Which do you normally use at this point, the OEM or Cometic MLS?
Interesting - haven't pulled the paperwork, but thought I'd been told that a redesigned gasket had been used. Between Powderpig and Andy saying that's an original design, they must have used an original.
Curiosity killed me so I pulled the paperwork. 5.4.04 - 126,105 miles - valve cover gasket p/n 11213-66021 gasket, cylinder (description on the paperwork) is what I was remembering. Price seems way to low for a complete head gasket job, even in 2004 - $365 parts and labor total at a dealer. Same thing or not? I don't know. I'd feel a hell of a lot better if this is the first HG and original design letting go at 202,000 miles and not a 2nd one.
Where's CDAN, Beno or anyone else for a conclusion on this original part number? Now I'm really curious! HG p/n just installed is 1115-66020.
EDIT - Pulled up the first googled Yota Parts site that had illustrations. Remember, I'm a one :banana::wrench: so just learning WTF the difference is here. Valve cover gasket is much higher on the engine block than the head gasket. :doh: Valve cover/valve cover gasket/cylinder head/head gasket/engine block(?) from top to bottom. :whoops: :hhmm: Me thinks I've just learned something. :cheers:
Would still love confirmation from someone that knows, but it looks like this is the first HG. I feel better now, even if the wallet is hurting.
That's definitely not a headgasket job on your first bill (price is too low, part number is wrong). Looks like this is your first!
Continuing to read and research online. Feeling much better that the engine's 'cherry' has been popped ;) at 202K for the first time and not 126K!
There is more metal and the metal extends from the firing ring to the head bolt holes to stabilize the firing ring from deforming around all the cylinders in the newer design.
I do not think I would recommend a cometic HG on a block that is not surfaced for it. Beside most of the blocks I have seen could not retain the MLS head gasket very well due to corision of the block.
Smooth, but then it did b4 too!
Time will tell how well a job Hanlon did. Mechanic that did all the work is an offroader himself and just had a big grin on his face when I asked who'd done all the work. I think he liked working on the truck.
For those curious, Here is a pic of the new style @ no1, you can see the darker grey areas/webs are the metal reinforcing the fire ring.
Still strange no1 failed before 6, Cdan might be interested in adding that one to his collection.
