HF2A replacement?
Falkner, MS
I have a '91 3FE FJ80 that has a busted transfer case housing. I have acquired a transfer case and transmission (have yet to pick it up) but I have been trying to figure out how this thing separates from the A440F transmission. I can't seem to find all of the bolts that mate the transfer/transmission together.
I have searched and can't seem to find a good documented removal/replacement thread for this particular unit. I have read that some of the transfer cases have to be disassembled to remove...just hoping my replacement is a little easier than that...:eek:
This is my first LC so excuse the lack of knowledge. Thanks in advance!
N.B. I just read about this stuff online, but I think you have to take the back half of the case off to remove the front half from the transmission. It's called a split case for this reason.
I've saw this before on the 62S but wasn't sure if it was the same with the 80S. I'd like to get an idea of how far I need to disassemble this thing before tearing into it. I guess if all else fails I can take the old one apart first...Just incase I take some bolts loose and things fall out on my head...lol
Ahh, THAT'S why it's called a split Tcase. I've wondered that for a long time.
2 forward facing on the passenger side, 4 rear facing, 2 of them up fairly high, the one youll need to lower the cross member for the trans until its on it last couple thread and 2 that are on the side, drivers side
17 mm bolts if i recall correctly
Awesome.
The forward facing bolts are the ones that I could not find. There is a considerable amount of grease/crud under there due to a trans cooler line leak. I will be making a trip to pick up the replacement case next month...hopefully I can have this thing built like I want it before next summer. :D
