HF Leakdown Tester - $29.95
Newberg, Oregon, USA
Wondering if it is time to begin thinking about a rebuild / swap. This should be just the ticket:
Here's a link: >>> Harbor Freight Tools - Quality Tools at the Lowest Prices
I picked up one of these at my local Harbor Freight store today for $29.95. The shelf said $39.95, but I had printed out the online ad and the clerk said they would honor the online price. I think they are normally $50 or $60.
Cool! I've been wanting one of these.
Cheers!
have thought about these.
tell us how it works.
leakdown tester
I assume you meant "how well it works" and not "how to use it."
Will do. I've got four engines I want to test right now, but home ill iwth the flu this week, so it is going to have to wait a bit.
I did go get one though. One of these is much more useful than an old fashioned compression tester. I was prepared to pay the $50+ for one if I had to. An acquaintance elsewhere with a lot of engine building experience said his HF tester worked every bit as well as the expensive ones.
Sorry if this is a dumb question but.....it only has a working pressure of 100 PSI. Aren't good rings and valves supposed to hold much more than that?
Would this be used for coolant system, EFI, oil pressure instead? Am I missing something?
thanks
thanks
No this is a cylinder leakage tester. I gather that 100PSI is commonly used, partly becasue it is just a good round number. If you leak down to 70 PSI you have a 30% leakage. Also because it is a pressure that common air compressors can typically reach. The idea is not to test the maximum pressure that the engine can handle, but to determine accurately how well the cylinders compare as to ring and valve leakage, and how they vary over time. This is not a compression tester that you plug in while you crank the engine. What you do is screw it into the spark plug hole of a cylinder at TDC with the valves closed, then you pressuriize it to 100psi iwth an air compressor, and watch the cylinder leak down over time with the engine static. An old fashioned compression tester tries to tell you what the maxium compression is, but that is confounded by a number of factors that are hard to control perfectly such as intake restriction, rpms and valve timing. If you know the original compression of the engine, you don't really need to measure the maximum, it is more important to know whether exhaust valves, intake valves or rings, are losing their ability to seal. I believe all cylinders will leak some; the idea is that they should leak as little as possible and all cylinders should be well balanced. The other big advantage of this tester is that since the engine is not running, it is quiet, so you can hear where the air is leaking from by listening for a hissing from the intake manifold, exhaust, or crankcase filler. Very cool... Try doing that with a compression tester on a cranking engine.
Easy to do, very accurate and repeatable results, if done repeatedly over time, you can see how an engine is aging very accurately. You can easily check a pulled long block with no ignition, intake, exhaust, starter, etc. and have a pretty good idea whether it is reasonably sound or has something catastrophic wrong, I will be using mine at every valve adjust on my air-cooled engines. Less frequently with my FJ80, watching it wear out would make watching paint dry seem like high adventure.
yes, how well it performs.
What is the typical time it would take to see the pressure go down in the cylinder? The rings all have a gap, I imagine, so this can't be that "air proof" on a longish time basis.
I have been thinking about this tool all day. I think my head gasket may be leaking, therefore I might be able to use a leak down tester to see if the head gasket is leaking..... Am I thinking right here or am I way off base?
Leakdown tester...
I believe that is exactly right. You may even be able to hear the hissing from the the gasket, or bubbling in the radiator if that's where the leak is going. It will certainly reveal any differences between the cylinders.
I haven't used mine yet, but it apparently just takes a moment for the air to leak down as much as it will. Reading the instructions, I guess you just hook it up, run the regulator up to full pressure and then turn the regulator back till the cylinder pressure gauge stops dropping, which is the pressure it will hold.
Here's a link to an article about building and using one >>> Tech Tip: Building and Using a Leakdown Tester
should be real easy to make something like that with stuff around the shop since most folks with compressors have regulators, gauges etc around anyway. and especially so if you already have a compression tester kit with the right plug thread.
sure, but...
Sure, but at $29.95, is it really worth the time and effort? I'm as cheap as the next guy, but at some point you have to decide where you want to invest your time in.
Two gauges, a regulator, three different spark plug thread adapters, quick disconnects, storage case, ... I don't see how you'd save any money doing it yourself, but to each his own...
Cheers!
from what I can tell, what they do is simply measure the pressure drop across a constriction, which is of course a function of the flow rate, i.e. the size of the leak. Bigger the leak, bigger the flow rate, bigger the pressure drop, the smaller the pressure measurement on the second gauge.
The number they use -% of something- means essentially nothing. So it's all based on relative changes.
it would be good to start generating a database on numbers for the 1FZJ with the same tool.
I did see something in the instructions about "zeroing" the downstream gauge. Not sure what that meant but may introduce some variations. Maybe best to have everybody set the upstream to 100 psi and report the downstream pressure in psi rather than %? Might make for better comparisons?
and how many degrees off TDC are the valves still completely closed?
BTT
any further experiences with these testers? I'm awfully tempted to do my engine just for giggles...
any repeatable numbers out there yet...?
Holy crap... How much pressure did you use! :eek:
doesn't take much. Say the pistons are about 10 sq in. 100 psi will give you 1000 lbs of force, of course.
all right!
got one too. I'm intrigued.
Any real numbers out there? Hopefully all the testers have the same constriction.
Would be good to have some numbers to compare to.
Critical to specify the entry pressure of course.
(hoping the 12 and 14 mm adapters work with the 80....)
added: I read the HF instructions for that tool, they are obviously non-sensical. Missing a key step evidently. And there seems to be a great deal of confusion out there about it. Pretty simple, really, though. IIUC, this thing is nothing more than an orifice with 2 pressure gauges reading pressures. The pressure drop (the difference between the 2 gauges) is related to the flow rate of air going through (leaked down). The RHS gauge reads a percentage value but that is irrelevant. The catch is that apparently the RHS gauge is only 15 psi from what I read out there. So folks will set the regulator to having the LHS gauge read 100 psi or so, which is what some testers out there use, and obviously, with no or little flow, the poor 15 psi RHS gauge is hit with about 100 psi and expires right away. Then people blame HF for poor quality hardware. Actually, it's really the instructions that suck. Anyway, what I think you need to do is to set the regulator so that the RHS reads 0 (meaning max pressure) *with no air flow*. The RHS gauge is then at max (about 15 psi apparently). Then you connect to the cylinder, have a leak flow rate and the RHS pressure drops. (The reg and comp better be able to keep the LHS pressure steady - check). Read the supposed leakdown figure (it's just a % of 15 psi). That's it.
That should work, except that you are limited to 15 psi in the cylinder. May or may not show small leaks?
Alternatively, just replace the RHS gauge with a 100 psi gauge, set the LHS to 100 and read the RHS in real psi. Works equally well and you can do a test with 100 psi (watch out for blowby, engine turning over etc?)
