He's dead, Jim.
Wow. That's something you don't see everyday.
Bubble gum and a coat hanger and you're good!
I have a new radiator on my porch, popping it in on Friday. Has a tiny leak (like a couple drops / per day) and I'm terrified of it blowing and cooking my engine. A half day job of replacing and the $400 total cost for radiator + hoses + doo-dads seems like a safe bet. I have some big trips coming up and don't want my HG blowing.
There's a joke there somewhere about pissing in the crankcase & your 80 deciding it's payback time.
I went with oem for my radiator. All the talk about what's "better" than oem has a lot to prove, considering the "bad" oem plastic/metal radiator has lasted ~200k miles and 20+ years. By that standard the next time I'll need to replace my radiator is in 2037.
That's nice, but the OEM FJ80 radiator was discontinued years ago.
That sucks. I'm sort of spooked because I figure the same fate will befall the FZJ80 in the next decade or two.
I used Gorilla Glue Epoxy on my radiator for a pinhole leak like that for short term fix. Have new Toyota radiator in garage but the epoxy looks stronger than the new radiator! Has been a few thousand miles....
Is the CSF-2709 good to go?
Radiator-3 Row All Metal CSF 2709 fits 89-92 Toyota Land Cruiser | eBay
Anybody used one of these? What do you think? Says it's all metal. I know I can find a radiator cheaper, but I really don't want plastic tanks.
Why not take it out and find a local Rad shop that can take it apart, clean it, repair it, rod it out, and weld the holes shut, and put it back together for about $250?
I just had a recore done on a Studebaker and it was $700. I about choked, but they replaced the entire center core. I want to keep it original.
Not trying to be "that guy", but from my maritime heritage I remember that all epoxies I worked with had max temperatures before they started softening up. With West Systems epoxy 110f was okay, 120 was yield strength. Anything north of that and it's pure lucky.
That was epoxy for bonding and via additives could be used for filling / shaping as well. Glass mat and fiberglass. Maybe you're using some high temp stuff I don't know anything about.
I just went through this on my 92. I tried using quik steel. It pushed the leak elsewhere. I replaced it with the CSF all metal radiator. Works like a charm. Worth the $250-300 for the peace of mind. Took about 2 hrs to take everything apart. 45 min to put it back together. New hoses on everything while I was in there.
FWIW, I replaced my original radiator at 17 years old with a CSF that last less than 9 years.
