Here's something interesting...
Eicca
Professional Noob
Utah
For you tranny techies I guess.
I felt my torque converter lock in first gear today. Prior to running errands, I tightened the accelerator cable to the point where even thinking about putting pressure on the gas peddal will make it start to rev (and it feels incredibly responsive.)
Anyway I was enjoying this newfound power while driving around and floored the gas to get out of the Wendy's parking lot while I had a gap in the oncoming traffic. Engine rockets up to 3,500rpm so very nice and I go flying out into the road. Then, while still in first gear, and without losing any speed, the rmp dropped from about 3,900 to 3,200 and then rose back to about 4,100.
Given what I learned in my recent "4-or-5-speed?" thread, I'm 95% sure the torque converter locked up at that point.
Input? I always enjoy transmission-related talks.
:beer:
I wish I was an expert on these tranny's, but I'm not....from what I understand on the A440F, torque converter lock up is controlled by the speedometer cable. When MPH reaches 47 or so, the torque converter locks up.
Previously driving around with all that 'slack' in your accelerator cable must have been interesting...
The whole rpm drop thing took place in first gear. I can always tell when my truck is in first because it has the most distinct gear whine ever
torque converter causes roughly a 2:1 reduction.
If in fact your torque converter did lock up, your RPMS would drop in half reducing the amount of torque the engine puts to the ground and decreasing acceleration. There is no way it is your torque converter locking up.
Where are you at right now? I am just at the bottom of the hill in Provo from Orem Center street. I could check out this mysterious transmission.
2:1?
When my TC locks up on the freeway I only see maybe a couple hundred RPM drop.
2:1?
completely different. When lock-up usually occurs, your torque converter is almost up to speed. The 2:1 is more like when you first step on the gas, then it catches up, then shifts again, drops back down to 2:1, then catches up.
If you get lockup right when you stepped on the gas, you would hear a big THUD, and rpms would drop down from say like 1800rpm(if that is the stall) to 900rpm. Not much torque at 900rpm.
Whatever it is it happens at around 20mph, and it didn't start until I tightened the living crap out of my accelerator cable.
It happened again today at 20mph in second gear, and the RPM went down by about 200. No loss in acceleration. I was taking it really slow so I didn't slide into a garbage can.
Like I mentioned, the first time it happened was at the highest end of first gear while I was flooring it. I didn't see my speed then; I was watching the traffic coming up behind me.
When the roads clear up I'll go driving and watch specifically for all this and then post my results.
lock up clutch
as mentioned earlier when you adjusted the throttle linkage you also changed the cable to the trans and now it is operating differently, the lock up clutch in all autos only drops the RPMS slightly some transmissions you cant hardly even tell, I dont know the exact RPM you should expect to see the eng drop when the converter clutch is engaged but its less than 200 RPM for sure
Look at it this way before the lock up clutch came along torque converters where 90% effiecient . so when the clutch locks up its only 10 % or so not a heck of a lot, 50-100 rpm range depending on stall speed I would say
Makes sense. Maybe the lock point is also determined somewhat by how far you're putting the gas peddal down?
Also, maybe my rpm drop is more noticeable because my torque converter is old and slips more than usual when unlocked?
re-reading your first post, you are talking about two things. First thing was that the engine revved really quick, and your throttle was responsive, indicating that you just dropped a gear for acceleration.
The second part of your post was that you dropped from 3900 to 3200. This would indicate a gear shift. Your going backup up to 4100 would just mean that your RPMS along with MPH are going up.
No indication of lockup.
My experience with lockup on my A440F before it died on me was that it only locked up in 4th gear and O/D. And the difference was only about 200RPM. No way would I EVER get lockup in 1st gear. I would get second gear way before lockup.
I also had to MANUALY control my kick down cable by acutally pulling on the cable while I drove around. If I did not pull on the cable during shifts, they were very slow and sluggish shifts. Also if I SMASH on the gas without pulling the cable...NOTHING. Trans would not down into a lower gear at all. I would have to pull the cable the right amount to cause it to shift when I pressed on the gas. If I pulled the cable too much, my RPMS would real high before shift, but if I pulled only a little, it would shift much sooner. The cable causes a VARIABLE shift point, and VARIABLE line pressure. The more you pull the cable, the sooner the downshifts and the longer you will stay in each gear. That is why tightening your cable caused for a quicker shift on the gas, and a longer RPM range.
Make sense?
Kind of. Keep in mind, there was no gear shift during the rpm drop I'm focusing on. Each of my gears whine differently and I can definitely tell the truck stayed in first gear when it dropped from 3900 to 3200. The rise back to 4100 was just the rest of the acceleration in first gear.
I'm writing from my iPod so I'm afraid I'm being incoherent.
From what I've read/understood the TC can only lockup in 4th and O/D. Rodney's Extreme Valve Body allows it to lock up in 3rd gear as well.
Again that's just based on what I've read and not personal knowledge......
Accessing 'mud from your iPod touch? Nerd:flipoff2:
That's right, infinitely mobile. Sucka :)
anyway I think I'll see if I can capture a video of the tachometer and see if that helps. Heh, maybe my valve body is messed up :)
eratic shifts
As you gathered you can rule out the converter clutch causing the RPM drop, The only possible cause of your symptom is that it shifted to 2nd and then back to first, the only other remotely related cause would have been a bind up in your trans which would have been accompanied with a noticable drag on the vehicle, play around with adj on throttle pressure cable and that will straighten things out hopefully,
