HELP!
Milwaukee, WI and Louisville, KY
Hi All-
If you have been following or helping on my other thread, thanks. I have decided to start another since I am now having another issue.
Quick background. Recently my rear lights started acting up. The turn signals wouldn't work while the light where on. Then it got worse and they wouldn't work at all. So upon recommendations from folks here I traced it back to the trailer light module that the PO must have installed. It was all burnt and melted. So I removed it by cutting the ground, located the splice places where it went into the normal wiring harness and removed the wires. They were connected with these little blue jackets, except for the wire that ran under the cargo area over to the drivers side. I cut that one near the trailer mod box.
Now is the kicker. The truck starts fine but will not move out of park. :eek: And no lights on the back work, or the interior dash lights.
I can press the break but nothing happens. It won't release to go into drive.
Push the little button on the top right (left?) of the tranny console.
Due to your light problems, the tranny doesn't know that you have the brake pedal depressed.
"We now return you to your lighting issues already in progress" :D;):o
Hang in there,
Curtis
