Help with wiring harness!
Argentina
HI fellow Mudders!
Doing an inspection on the engine bay of my newly purchased 1992 FZJ80, I found some plugs disconnected, and have no idea where they are supposed to be plugged.
Can anybody identify them?
Thanks in advance!
Cheers
Looks like you don't have abs? That might be what those plugs are for on that side.
South America some things might be different
Actually, it is a US Spec model. FZJ80 L - GNPEKA
Don't know why, Thought mine had ABS. I should check that out.
In case I don't have ABS, should I leave those wires disconnected?
Cheers
Just to clarify the ABS thing. My truck has brake drums on the rear, so that means no ABS?
Either way, are those plugs supposed to be disconnected?
Cheers
Finally figured out the missing cables/plugs.
The ones on the left hand side of the engine bay, apparently are for the ABS, which my 80 doesn't have.
The ones on the RHS appear to be from the radio antena, which was replaced with an aftermarket one!
Cheers
