So after recently completing my knuckle rebuild, then going back a few days later and resetting the pre-load to 30 ft-lbs I'm having an issue with what feels like an unbalanced tire at speed. It usually happens above 65mph and will occasionally smooth out close to 75mph. It seems to be worse when turning to the right around bends on the highway.
I already swapped the wheels and tires to a different set hoping to eliminate it and no change. Rotors and pads are brand new (Napa & EBC Greens) and the truck both tracks and stops very straight, so it doesn't seem brake related. It also rolls very smoothly and tires rotate smoothly by hand when front is in the air.
I checked for up/down and side-to-side wobble on both fronts and all seems solid there too. I did notice the other day that the front end was very springy when I pressed down on the corner of the bumper by hand. It has original shocks and springs and with the bumper, winch and armor on it sits maybe 1.0-1.5" off the factory bump stops.
Is it possible the wobble I'm feeling is a blown shock? The roads here in PA are very poor, lots of crowned transitions on the concrete and potholes of all sizes on the pavement. Not sure if the road + poor or broken shock would cause the issue or maybe tie-rod ends? The PS front tie-rod has a tear in the rubber. Also, the cat is rubbing slightly on the slider, but I'm not sure this would cause the feedback through the steering wheel that I'm feeling.
Any insight or help to further diagnose is appreciated.
