I just got done with the project from hell. PHH, flush, hoses, belts, new radiator, the list goes on.... I decided to upgrade to a 130A Sequoia alt while I was at it. I got a local one with reasonable miles on it and took it to two places to have it bench tested and they claimed it was good. I also upgraded to a 2AWG charge cable while I was at it.
Finally got the rig fired up and the volt light is coming on. Main batt was trickled charged beforehand. (New dual Die Hard Platinum's).
With harness to alt unplugged I was reading 12.5v, with it plugged in I was getting 13.8. (So I know the alt was engaging.) It stayed right in the 13.7-13.82 range even with lights, heat, etc on. Revving made very little difference. Seems reasonable since my battery was full. Voltage also read the same at alt as well as batt posts.
What's crazy is that the rig ran and sounded better then it ever has. Lights were brighter and no volt meter twitches when bottoming the windows out.
I've just dumped over 20 hours into this thing and if I have to tear it all back apart again I might cry.
(The joys of having a turbo setup is that everything takes twice as long....) I don't even know how I'm going to get that damn thing out again without pulling the shroud and radiator.
Any help would be great.
(The joys of having a turbo setup is that everything takes twice as long....) I don't even know how I'm going to get that damn thing out again without pulling the shroud and radiator.Any help would be great.
Photoman
