Help with vacuum line please.
Ok, I bought a new tank about four years ago for the rig and finally am going to use it. This tank however doesn't have the extra hose connections for all the tubing behind the seats and under the truck (yeah). Here's the rub, what to do with the stuff at the other end. ie.. the little electrical vacuum swith thing on the drivers fender with about 4 or so lines coming off it with one which used to go to the tank. Can get more detailed if needed but figured you guys already know how stupid I am and have probably been there done that. Any help would be appreciated.
1971 fj40
1f / 3 sp / vacuum xfer
Thanks
Les
You don't need any of that 71 junk, and you're really better off without most of it. If you had a real charcoal canister, it would be different, but if you're stock, you don't.
If you want to get the benefits of a real vapor recovery system, you will need a tank with the extra vapor fittings to start.
You can ditch all that stuff, including the big canister in the middle seat back. As far as the cylinder on the driver's fender, all you really need from the vacuum system is a single hose running from the secondary [outboard] side of the carb to the vacuum retard diaphram on your distributor, so that when you are under a really heavy load [pretty much the only time your carb will need the secondary] you'll have a little retard in your timing to reduce detonation.
BTW, WELCOME TO IH8MUD. We don't really have a newbie section here, so you can just add a little info about you and your rig right into this thread; I don't think the moderators will mind. ;)
Awsome info. I tried a search and couldn't figure out what to put in to get good results. I am in the Air Force, and bought a 71 fj40 7yrs ago. Money, family and overseas asignments kept me from touching it until about 6mo. ago. So far money and family are still an issue, I have managed to rebuild both axles, and completely redo the entire front end (wanted power steering but rod ends were a lot cheaper). Just finished up all the brakes this week, what a chore (drums). The other main issue with major upgrades is, this is a New Mexico vehicle with 66k original miles. Had it painted for me while I was overseas (nice tan and white basecoat clearcoat), without one patch of metal. Due to the low mileage all metal parts are just getting broken in, but all rubber parts are dried out. Makes it kinda hard to go to disk brakes when you go to replace the inner seals on the birfs and the brake backing plate bolts still have the original safety wire installed. Hasn't run in at least 4 years though and going to try and tackle that next. Again thanks for the info. Will probably leave the junk in the seat just for looks.
Les
Hey, Les, try to post up some pictures for us.
Are you sure that is a '71? I'll bet it is actually a '72 with a late '71 build date from your description.
Not sure how to post photos. The booster is newer, found a 60 in a wrecking yard and for 100 clams got the disk brake conv. setup, just used the booster so far though.
Les
Still have all original parts, lights aircleaner, seats, spare tire swing, everything, just need time (again Air Force and Family) to bolt it all together. Plan on rebuilding engine trans. and xfer as all leak from every seal. Would like to lift and put tires on, bought a set of stock widened rims several years ago, problem at present is if I do, it won't fit in garage. So the coolness factor will have to wait on mechanical factor. Again thanks for the help.
Les
