help with starting problem
Laurens
My 1976 FJ 40 runs great. I drive it 30 miles each way to school. The other day I drove my 30 miles, turned off the engine, remembered I had to run to K-mart. I tried to immediately fire the truck up and it did not want to start. I sat for a few minutes and it then cranked right up. I started to try this everytime I cut the truck off and it was not a one time thing. It seems that after a drive and the engine gets warm...no fire. Any help?
my best guess is after you shut it off it stops burning the fuel that your pump sends in, therefore it gets flooded for a few minutes... when you wait for a few mins more, the fuel evaporates allowing you to start it up again.
seems like it would be a common problem, however i've never had it happen (electric fuel pump) so i can't really tell you for sure. :cheers:
The carb is only adjustable for idle mixture and speed, so this won't help. I agree with the flooding after shut off. Does your carb fan work? Also try starting it with the gas pedal held all the way to the floor during cranking with the choke off. If it starts right up this way it is probably flooded.
thanks guys....i will try that when i get home...any way to fix this? i was thinking the floater might have been letting to much fuel in. I replaced the coil on it and went to Autozone to get one.It is smaller. Does anybody make a quality coil for this?
as far as i know there's no real solution to the problem, but to tell you the truth it doesn't sound like that bad of a problem. with my elec. pump, it is MUCH easier to flood the engine and when it does flood it REALLY floods, taking a few hours to clear out. in my opinion, you might be better off not worrying too much about it until it starts causing further problems :beer:
