I'm at wits end. Two weeks ago I hit cut in pavement that was pretty rough at about 20mph. Soon after I notice a sound like rocks flying off tires onto the underside of body. No rocks in tires though. I have looked at everythingand cant find source. I have:
My 40 is a 1970 and has a fresh 2F with H55 5 speed and split T/C. Converted to mini box power steering, has newer disc front end. Has 4" spring lift with all new shocks and poly bushings on springs / shackles. All new motor trans mounts.
Noise seams to be right under tranny cover. but is not in the same place all the time. Cant feel anything hitting cover when I put hand on it. Cover was cut and lifted to give plenty of clearance over top of trans.
Any ideas ? My best guess is metal on metal in a bind somewhere and flexing of chassis makes the nose come. Just cant find it after two weeks of looking. Finally decide to just drive it and if serious it will get worse and I'll find it. That plan isn't working, noise just stays the same.
Thanks, Shaneus
- Lifted and spun each wheel.
- lifted one rear wheel with trans in neutral (to spin rear drive shaft and transfer case).
- Put transfer case in neutral and fired up engine and run through all gears.
- Pulled flywheel inspection cover off and found nothing visible or broken parts (thinking maybe spring from disc or pressure plate).
Thanks, Shaneus
