I also assumed it meant distributor CAP, not the dizzy itself. Since a new OEM dizzy costs over $400, I'm pretty sure it is the cap.
Replacing the plugs isn't bad at all. You need to remove the air intake hose (to give you some room). Then remove the plastic cover on top of the valve cover. At which point things become quite obvious. OEM wires, as well as the cap, come numbered so you can't screw it up. They are also already in the wire retainers, so it is plug and play.
The plugs are set deep in the head, but a 4" or 6" extension (as well as a spark plug socket with the rubber inside) is really all you need. But if the stock toolkit works - even better.
I guess I need to read up about the timing in the FSM. Although I know initial timing always needs to be set, I thought the ECM pretty much takes care of small timing differences. Even still, that shouldn't be too hard - but for $45 no biggie either way.
Gabe brings up a good point about putting the cost in perspective. In short, it doesn't sound like you are getting ripped off (especially with the PHH replacement).
