help with lower ball joint issues on my 200
southern california
i recently installed a 2 inch fox front suspension lift and stripped the threads on the lower ball joints on both sides of the vehicle (i know, i know. I'm a dummy)
my question is how hard is the install of just the ball joints only? should i just save time and take both tie rods with replacement ball joints to the mechanic to install? do they need to be pressed in ?
note: my local toyota dealer quoted my at 100$ per ball joint. thats not too bad
thanks in advance
You can buy ball joint tool kits from Amazon for $100 or less. Pretty easy to use, and then you have the tool.
The lower ball joints have a VERY tight interferenence/press fit... I'm not entirely sure some of those tools are up to the task...
Thanks. I will try renting a c clamp press tool from autozone to replace the ball joints. But honestly I'm kinda over it and I just might call a mechanic to finish it. Lol
Thanks again for the responses
Sorry to hear of your woes... we've all been there before :D
Putting OE ball-joints back in?
