I recently de-smogged by FJ60 which has been a great learning process and starting to understand all the components of this engine. I had the manifold apart and the spring and flapper appeared to be functioning however from what I can tell there is supposed to be a counterweight on the end of the shaft which I don't have (see pic). I can put some vise grips on the shaft and rotate it counter-clockwise so the flapper can rotate however without this counterweight I assume the flapper never moves into the 'hot' position which is just forcing exhaust gases up into the intake area. Any thoughts on this and recommended next steps? I've seen some threads on removing it and using the block off plate but I do live in Montana so there is value in this system for cold starts. Thanks!
