Help with ABS sensor
Middle Tennessee
Hi all
Today I was trying to reboot the ps front axle and ran into a problem with the abs sensor, I couldn't remove it.
Took the bolt off but the assembly was not coming off. Tried prying with a screwdriver and got it to separate a bit, but still not coming off, so didn't want force it.
Is there a special technique? Or just jerk it off?
Thanks
Just one bolt. Be careful prying.
Probably rusted in place. Fix is to remove hub and tap it out from the inside, hopefully without damaging it. Use a wooden dowel and hammer to tap it with.
Leave it alone if it's a good sensor, removal can be destructive when they get stuck.
You don't need it out for the re-boot anyway, are you needing to replace a bad sensor?
The sensor is good, just tried to remove it to no put stress in the wiring when taking the ball joints to remove the cv axle
I just disconnect it under the hood and then leave it in the knuckle.
