Help with a part name/number
Phoenix
I cut a hose to install and use the Preston radiator flush kit. I don’t like the idea of running my truck on rough roads with the jury-rigged hose in place, so I’m now trying to replace the hose. Problem is that Murf and I are having trouble figuring out the part name/number. The hose can be seen in the picture labeled #4 in post #7. https://forum.ih8mud.com/80-series-tech/14891-cleaned-my-cooling-system-full-scoop.html
Anyone know the part name/number or order this part?
Thanks,
Pete
Got it! I should say Murf got it:grinpimp:
Part is 87245-60340
Thanks Murf, you are a phenomenal resource and our club is lucky we have:cheers: you.
Pete
If you want to keep factory clamps and OEM look you can order the assembly 87209-60290
That is assuming you do not have the Toyota SST tool for installing the factory pin clamp 87124-28030
Mostly depend on how anal of a OEM guy you are
Phil,
Just this one time I hope you're wrong. I ordered part 87245-60340
Phil,
87245-60340​
Probably bad wording on my part...its an option on replacing the assembly(87209-60290) to keep everything looking OEM
or replacing JUST the 90°hose(87245-60340) using an aftermarket non OEM hose clamp.:frown:
Part Number 8720960290
Part Name HOSE SUB-ASSY, WATER
MSRP $77.09
CBT $55.62
Part Number 8724560340
Part Name HOSE, WATER
MSRP $26.69
CBT $19.26
Hi,
What is the associated SST p/n when installing 87124-28030 (pin clamp)?
Thanks!
