Help with a Birfield.
California
I put the cage back in the wrong way and now I can’t get it back out. Anybody have any suggestions, aside from getting a new one? Thank you.
You can't get the cage out of the birfield, with the axle in it? If that's the case you will probably have to destroy the c-clip, beat off with a bigger hammer. Since you already disassembled it once I assume you are informed as to how to remove the axle from the star, yes?
If you only put the cage in upside-down, you have to remove the balls, flip the cage sideways, and line up the holes in the cage with the flats in the bell to remove it. Or just flip it over.
Tap the cage on one side with the balls still in the birf and remove the balls do this till you get all the balls out then put cage 90 line it up and it pulls right out, the axle has to be removed obviously
