Hi all, I am in the middle of my 3.11 gear install. I just pressed off the Front drive gear, roller bearing, Hi speed output gear and needle bearings.
I went to remove the Hi/Lo clutch sleeve and synchro ring and the springs inside the clutch hub popped out. These seem to press some keys in and out of the synchro ring when the sleeve is slid up and down.
There are 2 springs, do they just overlap eachother so each key (3) has part of both springs behind it? (Like how it is assembled in the last pic?)
See pics:
See pics:
