put lots of time into the upper link here. spent lots of time just finding a seating position where I could see my weld. kinda like twister except you keep getting burned as you play
Dustin, what about the inside of the 3rd link mounting point? It looks like you only welded the insde tab on one side. Could this be a casue for weakness? Is there a way you could weld both sides without cutting off the entire bracket?
(Oh and the 37s rock!)
hmmm thats a really good idea. and a threaded bucket would allow for a solid flat surface at the top of the retainer for the bump stop to contact instead of a screwed on floppyish retainer that cant take a bump stop hit well. only issue I see is that the spring isn't a consistent thread all the way to the end but is smashed together at the end. perhaps If I cut the last 2 inches off the spring....Why didn't you make the spring thread into the buckett?
you would not need a retainer then. And that thing is not coming apart any time soon..
Got enough molten metal?
I'm glad thats not my sink. WOW! But the pie! YUM!!!!
Dustin.....I'm missing several rolls of .035 MIG wire. You wouldn't know where they might be would you???
No problem, Slickrock. I don't neet it for my rig anyway.
I was looking at your rig again... Your front bumper is too nice to cut up much. Can you move the bumber forward a couple of inches instead??? With those fourty-something tires your approach angle will still be good. You might also gain some airflow for your intercooler and/or hide a winch inside the bumper.sorry for the delay. ran into a bit of a wall in fitting the front 42's into the available space in the wheelwells
as shared earlier I was planning on trimming away some of the fender and other firewall structures at the rear of the front wheelwells so as to allow the 42's some room to move. by doing this I could keep the wheels out of the front bumper and radiator support. after mounting a hub and tire I mocked up this scenereo by flexing and turning the 42" irok within the wheelwell. even with trimming at the back of the wheelwell the tire still hits the radiator support in the front.
But it gets worse. the factory trackbar hits the tierod on the d60 if the axle is moved back like I wanted. So if I move the axle back I have to cut out the factory trackbar mount and move the trackbar back. Once I realized all this I decided to do the right thing.
I need to move the front d60 axle forward a couple inches of where the factory toyota axle was. This requires more work. I marked up my custom front bumper that I worked so hard to make as it will need to be generously cut to let the tires mover forward. then I hacked away at the radiator support. and inner fender. I carefully bent the condensor lines and moved the condensor almost to the framerail. It can be done. tonight I got the front axle into position. I spent over an hour making a frame to hold the blumb lines in place for mock up. I got one tab welded to the axle. Cut once-measure 22 times
