I read through all the posts on this common mod and could not find an idiots guide to wiring the switch, I even managed to blow a inline fuse trying to read some of the wiring diagrams on here. I am not good with wiring and don't want to cook anything. I had the lights (hella 500s) working with the provided switch but I wanted to use a factory switch instead. I found a defog switch from a 94 corolla that looks good but I just don't know how to get it wired up...
Could some one do a little drawing on this photo of where each wire should go?
I can tell you this.
The black wire is the switch ground
The Yellow wire goes to the relay
The light greenish wire goes straight to the positive on the battery, it is supposed to go to the high or low beam light positive wire but I wanted to be able to turn them on independent of any of the other lights.
I think I also need to tap a wire to get the switch to light up but not sure I'm even going to tackle that considering how bad I am at this stuff.
