i think i just messed up my battery. i've done a search for "battery" but it seems that there is not one battery that we can all agree on. how am i to pick?
need single battery to run 12k warn and engel fridge. i want a good powerful battery.
Wow-great minds think alike. I just bought the Grp27 Kirkland Marine this weekend and installed it as the primary battery in my FJ60. By it's specs, it should run a winch and a fridge no problem. ie plenty of cranking amps and deep cycle capable. It's got 110 amp hours which is like twice the energy content of most batteries (read great for running a fridge)
The $$ option is the Optima D31M. It's big, lots of CCA and can deep cycle, but then it's $200. I have one on my 80 series and it's been great for 3 years.
Must have a bunch of great minds here. I put a Kirkland group 27 Marine battery in my 80 in the 2nd position, but is only used if the primary runs down. I will need to find a reverse terminal one when the time comes to replace the primary. I wish Toyota had not done the reverse terminal thing on the 80s, or made the wiring harness longer.
As painfull as it was, I finally settled on an Odyssey 1500 as a main battery. Since it's going to be my only battery for awhile, I went overkill. I think the battery is one of the most critical componants of any motorized water or land craft, so, I spared no expense. No juice, no start, no ride = you walk (or swim).
Nothing like waking up camping to find out that the glove box was left open all night and the light drained the only (lead acid) battery you have. I plan on punishing it. t will be sitting outside during the winter so it'll need to survive the Rocky Mountain extreme temperatures.
It will deep cycle between 400-500 times, doesn't require maintenance, it can survive most freezes, won't leak acid all over the friggen place...(even if it's split wide open) and it meets MIL Spec shock vibration and impact tests.
Odyssey claims a 10-12 year design life and an 8 - 10 year service life...we'll see. I'll most likely end up moving this over to the second battery location when I can afford a dual battery rig.
There's always the guy you meet that spends 30 bucks on a battery and it's going on 8 years of service with no problems...ih8 you!
I have three of the Oddyssey 1700's. Sure they cost a bit more, but they last a heck of a lot longer too. I just bought these three about 3 months ago($700), but the last time I bought batteries($825 for three Gates 2000amp) was 13 years ago.
I guess you could go either way, cheaper batteries, that won't last as long, and you have to swap them out every couple/few years...............or
spend some money, do it once and for the next several years, forget about it.
In the long run, it may balance out, meaning that if I got three of the $70 Costco batteries every three years, that would cost me $840. I only payed $700 for the three Oddessey batteries that will last about the same amount of time as the Costco batteries, and out proform them as well.
