Help - Where is the fuel filter?
30°54'01.53N / 84°04'56.04W
Where the :censor: is the fuel filter on a '92 FJ80???
FSM tells you HOW to change it, but does not give any indication where its at (atleast that I have seen). My GMC has it lined with the frame...dont see it on the frame of the 80.
I also can't find it.
I just changed mine the other day. It is under the intake. There are two 12 mm bolts which hold it on to the intake underneath. I just used a swivel socket and a long extension to reach them. Before I took those off I removed the fuel lines. I think they were 15 or 17 mm. Not much gas leaked out. It took about 10 minutes. The fuel lines have small washers which you should probably replace, not sure if the new filter comes with them or not. I reused one of the old ones and it doesn't and hasn't leaked.
But is there going to be a difference in location between the 4.0 & 4.5???
Can anyone with a '91 / '92 out there confirm this???
Howdy! That sounds just like the one on my 85 Toy mini. I sure wish somebody did a kit to relocate the dam thing. John
Found it!!!! Just below / to the side of the oil filter. Looks like a bitch to change...especially if the engine is hot.
From a top side glance. it looks like its the original on this beast...after 183k miles.
deleted because bad information
Fantastic pix! I'm always amazed that so many of you mudders can work so fast. It would take me 10 minutes just to grab the necessary tools, another 20 minutes of looking around under the hood to make sure I could identify the key bolts/nuts involved, another 30 minutes to actually remove the parts and make the change (big hands and I work slow) and another 20 minutes to put everything away and wonder what I did wrong.
But that is why I am only a 1 :banana: guy.
:cheers:
Here are some pictures. I couldn't find it the other day when I looked for it either.
Those are great but unfortunately the original poster has a 92' so his probably filter is in a different location. (I have no idea where the 3fe filter is)
On the passenger front frame rail...
The hardest thing I've done on my Cruiser. Took me like an hour and a half cause I had to find it, and then find out how the hell you're supposed to get a socket wrench in there to remove the filter.
Extensions. You're going to need a lot of socket extensions.
