HELP! WEIRD STARTER ISSUE?
Missoula, Montana
Hey Cruiser Bro's and Broette's,
I have a 1966 (likely a 1964) fj40. Stock (except) HEI mechanical advance ignition from Man-a-Fre. I think it's called a lightning strike or something like that for our purposes. Any help, thoughts or directions would be helpful.
Symptoms:
1) No power to starter through igniton key switch.
2) When I "jump" my starter from solenoid to starter it does not engage and just spins but seems to be getting power.
Attempted diagnostics:
1) Replaced starter and new starter did the exact same thing. Had old starter tested and test came back that original starter was OK.
2) Battery is good.
3) Fuses are good
4) Old ignition switch (at the key) tested and has continuity when I turn the key.
5) Rolled it in gear to see if flywheel would do something with no response.
Help: Are these two problems related? No power to turn it over from ignition switch but even when jumped from solenoid starter doesn't engage and just spins.
Any tips troubleshooting tips would be helpful. Thank you!
Gene
Do you mean you're jumping these two together?
You should jump the two in the pic. There's a whole lotta amperage passing between those two big nuts. too much for a small jumper wire to work. That's why there's a solenoid to begin with.
You simply want to apply 12 volts to the spade terminal.
Jumping the nuts bypasses the solenoid shown in the pic above. Sounds like a bad solenoid/Bendix.
So... Am I not jumping it correctly? I had the same issue with the first starter but when I tested it at Autozone they said it was fine? Check out my full write up above. Do you think the tester isn't picking it up and I have two bad solenoids on two new starters? That would be some baaaad luck but I'm guessing that wouldn't be the case. But that's why I'm here asking. Thanks for your feedback.
Ok I'll try to jump the two in the pic. But would that effect my key still not turning on the starter? Check out my whole write-up at the beginning to see it all. Thanks for all of everyone's help in advance! Cruiser bros are the best!
Look at the schematic again. The HIGH current from Batt+ goes to the starter as shown. Then there is a wire to ignition switch, 12V, to engage solenoid. When you start, solenoid engages and allows High current to spin starter. Now, please look at starter ground wire to frame, you see it on the schematic grounding the starter to frame.
ground symbol
Two separate issues. Diagnose one at a time. Jumping 12 volts to the spade terminal is a good start. You can jump it from the big nut that the battery cable is connected to or you can run a jumper right from the battery + terminal. If that doesn't crank the engine over check the big cables and grounds like mentioned above.
Thank you! I'll try that when I can and report back.
Check the starter ground and battery ground to make sure they are not corroded. Easy Check - Easy Fix.
I went ahead and replaced both of mine when I installed my new starter and alternator.
Just one last thing to worry about while on the trail in my 74'.
I'll check that while I'm at it and report back! Thanks fellas!
The starter ground wire goes to the frame as mentioned above. See the two red circles on the left, and red line tracing the wire below. The red circle on the right is obviously the positive from the battery.
ground symbol
I will take some pictures when troubleshooting the other items and report back if it doesn't work. I have the schematics but am way too ignorant to track. Thanks for your help!
