Gents and Ladies,
Sorry for the post because I know some of this has already been answered in previous posts, but I need confirming answers for two separate problems. My truck currently is sitting at Jim Hudson Toyota in Columbia, SC and they can't see to find the problem.
PROBLEM #1 - Speedometer and Odometer not working. I have read many posts that point to the o-ring being bad. As I don't have much of a driveway to lift my truck up, to replace this part, I took it into the shop.
They are saying there is a sensor that went bad and it is going to cost me $280 in parts. Funny thing is they replaced it and it is still not fixed. I explained that the o-ring needs to be replaced inside the transmission case where this sensor is. They currently have NOT done this. They are also blaming my Speedo box but my speedometer was working on and off before the Speedo box was installed. Is my assumption about the O-ring correct?
PROBLEM #2 - I recently replaced the charcoal canister and all the rubber tubing that connected to the existing canister. I did this because in high elevations I was getting a major smell of fuel vapor. Replacing it seemed to work.
Now I am having a problem where if I drive long distances and get off the interstate on an exit ramp, my truck stalls out by the time I stop. RMPs go from 2k to 1k to 500 to 250 and then out before I stop. This also happens a lot when I am at a high elevation and I am coming down a mountain side, my truck will stall at the bottom of the mountain. It never stalls going up or sitting and idling. Just when I am coming down and have left off the gas.
Again, sorry I am asking for help without doing more research on the forum but my truck has been sitting at the dealership for 3 days and they can't fix anything or figure out what is wrong. I thought would be simple.
Sincerely,
ROLDS
Sincerely,
ROLDS
